For Sale - PC Security Cases | |
I have 7 of these up for grabs.
Here is a link to the manufacturers webiste with the details on it.
PC Security Cases
These weight in at approx 13kg, are built like the proverbial and resist attack for a good amount of time.
They are designed for pc's with the following dimensions, give of take 15mm either way.
H: 15.65" W: 4.59" D: 14.25"
H: 39.75cm W: 11.66cm D: 36.19cm
Deliver I would imagine to be about £20 a pop including finding something to box them in or you are welcome to pick them up from me, located near Thorne, South Yorkshire, OR i will be heading over to Warrington along the M62 on the 17th so could drop some off if you aren't too far off the motorway or pickup from my family in Warrington after the 17th.
I have seen these items tested and generally unless you can beat the lock (not easy i may add !) then generally anything inside it gets damaged trying to get it out.
There is plenty of ventilation on the units to allow a cool running machine and also the ability to use security bolts to lock the cage into a concrete or such like floor and then mount the PC in the case and lock it up (this is the ideal method to ensure good protection).
I've installed a few in small business's and SOHO's but am now trying to clear my garage out for a house move next year and these are taking up space that just needs to be cleared ( as SWMBO'd has said so )
Im looking for the princely sum of £60 each. This is 36% of the original price they cost so a real bargain to whomever wants one.
I can sell the whole lot together or as singles is anyone wants.
