Home > General > VentureCam owner near Brighton, Warwick or Banbury
Martin
Site Admin
Hi all,
Does anyone in the above areas have a RR equipped with a VC dock in which I can try my camera?
Failing that, could I post my camera to someone to see if it'll take charge?
Ta Smile
Martin
Post #91640 11th Nov 2011 3:21pm
you're welcome to post it to me but i dont know if you'll get it back though.. Laughing ... - .- -.
Post #91641 11th Nov 2011 3:24pm
Martin
Site Admin
Ha! Ner Ner
Post #91643 11th Nov 2011 3:27pm
You could try and ask daveo if your camera is faulty.. He kindly brought back two of my venture cams to life.. Previously..
Post #91695 11th Nov 2011 6:20pm
Martin
Site Admin
If it won't charge then that would be my plan Smile
Post #91697 11th Nov 2011 6:26pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Ive got a spare venture camera (somewhere) you are welcome to Martin Thumbs Up - it will need a recharge but I know it works (it was brand new from LR Dealer)
Post #91755 12th Nov 2011 6:12am
Martin
Site Admin
If mine's u/s and won't charge and can't be revived then obviously I'll be on the lookout for a new one.
This is for a project which currently consists of these separate items:
  • 2008 RR
  • VentureCam
  • Camera dock
Post #91763 12th Nov 2011 9:50am
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
If the only fault with your VentureCam is a dead battery pack which is the problem i have just had it is quite straight forward to open the cam and replace the pack for only a small cost, the cells cost me about £12 on the internet. The cam is only held together with three clips and a small amount of black sealant which gives way quite easily and without marking the case, after cleaning away the old sealant and applying new it clips back together without any evidence of being opened.
Post #91807 12th Nov 2011 4:37pm
Martin
Site Admin
Bump
Post #92235 14th Nov 2011 9:44pm
my offer still stands ,and you will get it back .. Wink ... - .- -.
Post #92237 14th Nov 2011 9:46pm
Josh Wyatt
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
Bit of a late reply I know, but I'm in Kidlington and have a venture cam equipped RR...let me know if this is of any use to you?
Post #93472 21st Nov 2011 12:33am
