Home > Maintenance & Mods (L322) > whats the best LPG conversion
fisha
Here are some pictures of my original install:
Its a small tank, tops out at 54litres fill, which does my head in something rotten ... its going to get changed to a larger tank further down the line, cant stand having a range of only 150 to 180 miles.
Now, here is the original reducer that was fitted:
This actually began to fail, the seals went on it and at certain termperatures, would leak out gas which you could smell. I also think that it was positioned too high up ( look at its height compared to the expansion tank and with the pipework at the bottom as well, I sometimes think the reducer air-locked.
Cause it was failing, I bought a new Romano reducer. I couldn't get like for like as they had uprated the reducer. It was notably bigger, and had a different orientation for the pipe work. It also had an 8mm input where as my system fitted was a 6mm feed line.
When I fitted it, I mounted it much lower down to stop air locks, and also had to put an inline adapter on the pipe to change it to 8mm. Since being fitted, I've had zero issues.
 V8 or else ...
Post #90994 8th Nov 2011 11:45am
Polux
2005 Range Rover Autobiography 4.4 V8 Monte Carlo Blue
sorry but going to have to say PRINS VSI
BRC comes in second
Post #91014 8th Nov 2011 1:54pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
BRC for me, had it on many cars now.
PRINS is apparantly better, I had it on one of my cars and it ran just as well as the BRC.
BRC i've put on 180k's worth of miles on different cars. Never a problem. Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #91152 9th Nov 2011 9:04am
These pics aren't my install but done by the same guy and mines identical.
The install is great. You wouldnt know it was converted without really looking and and the filler cap. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #91528 10th Nov 2011 9:48pm
