Home > My Range Rover > 2006 Headlamp Adjustment ???
andy vash
I’ve just carried out a 2008 face lift on my 2002 range rover. But when I drive the lights are shining in the faces of oncoming traffic. Is the any adjustment on the 2006 to 2009 lights ? On the top of the light unit there’s an Allen screw which I’m assuming is the lamp adjustment
Post #89503 30th Oct 2011 1:38pm
fisha
My 2002 ones have the allen screws in the top to adjust.
Simple thing to try is park it a bit away from a wall, put the lights on, and adjust the allen screw and see what happens to the cut off line.
Count the number of turns you do first, so that if it goes wrong, you just turn it back to where it was.
You'll quickly find a decent height that suits you. Although I think mine are a little too short for higher speed stuff like unlit motorways. I may tweak it a little yet. V8 or else ...
Post #89506 30th Oct 2011 2:02pm
face lift headlights self adjust/level , they go up and down and side to side, but you have to have the 2006 onwards LCM to do that ...on a 2002 conversion you will have to make do with manual adjustment.. ... - .- -.
Post #89508 30th Oct 2011 3:04pm
