![]() | Home > General > PDC |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
Hi, I've posted on this.
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Hi there whats the best way to check if its the module...just turn around the connections on the pdc ecu in the boot? If this makes the front work then i know its this?
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
the front ones can also be disabled via test book, mine didnt work when i first bought it untill it went in for a software update and everything was reset to factory then they worked for a little while until i had a wiring fault. |
