![]() | Home > Technical (L322) > Suspension Fault - advice please to a newbie |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Hi, I've got the Vogue SE with the standard 19" alloys, but I'm sure somewhere I read that if you put larger alloys on you had to recalibrate the air suspension etc ( or do the wheels and tyres overall diameter still equal your old ones i.e. old ones presumably 19" + higher profile tyres , new ones 22" with very low profile tyres)?
That will be the usual code fault on the FFRR, most likely it's the small compressor valve inside the boot under the spare wheel that probably just needs taken out and cleaned as sometimes it gets jammed.
pyramid1235 Member Since: 25 Mar 2009 Location: Glossop Posts: 20 ![]() ![]() ![]() |
I had very similar problems with my suspension when i first got the car - after cleaning out the compressor dump valve in the boot all has been ok its a simple job to do the compressor is in the spare wheel well. there is a thread on here that gave me enough info to do it, after changing a wheel / wheels im sure there is a procedure to follow thru your navigation set up screen to reset distance you should try this first (RTM)- From memory this was how to clean valve..
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
Where is the air intake for the air suspension by the way? I presume it takes air from the cabin (as it would be cleaner and not require a vulnerable external intake. Is the air filtered or dried (I am assuming not).
There is a dryer/filter incorperated into the system:
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
No stock RR ever came with 22" wheels firstly. The rolling circumference of the factory 18", 19" and 20" alloys with the standard tyre sizes are all the same. If you fit aftermarket tyres or larger alloys such as 22", then you are messing with the basics. What effect this has exactly I am not sure, have never seen the point of 22" wheels. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
sbrhodes Member Since: 04 Jun 2009 Location: Cheshire Posts: 5 ![]() ![]() ![]() |
Many thanks for the advice received, it's all a bit above my head but am booked in with the Landrover / Range Rover specialist tomorrow so will print off these responses and ask him to check.
In answer to a couple of the questions raised I have the TD6 Vogue SE.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2072 ![]() ![]() ![]() |
My local stealer advised that RR do supply genuine 22" in the USA |
Typical Americans, bigger is better etc! Discovery 4 HSE
Just a quick update, I got the fault fixed and it was indeed the exhaust valve and the drier on the compressor, many thanks for all the assistamce. |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
hi can i ask were the exhaust valve is and the dryer? when i looked under my spare wheel the tank is sealed do i need to open this up ? its a facelift model 55plate and its saying there is a suspension fault |
The compressor is under the black cover (coated underneath in soundproofing) that looks like a tank under the spare wheel. Remove a few screws and you're in.
hi thanks for the help if i open the black unit will i need to reseal this ? to stop air leaking again -when i bought the car it sometimes makes a popping sound from the black box as if the air is pressurising inside this unit is that normal?? |
