Home > Technical (L322) > Navigation - Destination entry on the move
pyramid1235
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Currently my sat nav disables destination entry once speed is above about 5mph, i have had a range rover sport hire car for the last week which allows destination entry on the move at any speed i have found a landrover service bulletin that tells the dealer how to enable it via their diagnostic tool fault code reader does anybody know of anyother way other than pay the dealer to do it..... Below is the landrover service bulletin.. can any of the OBD readers or other handheld devices that are cheap to buy help you do this?? Confused
Number LTB00044 26th March 2007
Models:
Discovery 3
VIN-range: 5A000256-6A413981
Range Rover Sport (LS)
VIN-range: 5A900109-6A983116
Range Rover (LM)
VIN-range: 5A180215-6A239035
Markets: UK and European Markets Only Section: 419-07
Summary:
Customers may request the ability to be able to set navigation system destinations or way points whilst the vehicle is in motion. This feature may, as a customer chargeable enhancement, be enabled by following the Service Instruction below.
This enhancement is available to customers on a request only basis. Warranty Claims may not be submitted for this enhancement; this is a customer payable upgrade. Customers must be advised of the warning message on the navigation system which is displayed each time the system is operated and that they are responsible for ensuring they understand the message displayed. The customer's request must be clearly stated on both the repair order and any invoice and it must be clearly identified that this upgrade has been completed at the customer's request.
Service Instruction
NOTE: The Authorized Repairer must check the vehicle specification on DDW to work out which modules potentially need updating. To record which modules need updating and to give a time allowance for each operation (for information only) see Illustration Attachment 1.
1 . CAUTION: This procedure requires IDS DVD105 Patch File 6 software or later.
Connect an approved battery charger/power supply to the vehicle.
2 . Connect IDS to the vehicle and begin a new diagnostic session, by entering the correct VIN for the current vehicle.
3 . Follow the IDS prompts to read the vehicle configuration.
4 . When prompted 'Do you wish to read diagnostic trouble codes?' select 'NO' and then press 'tick' to continue.
5 . When the 'Content Model' is displayed select 'Vehicle Configuration' tab.
6 . From the 'Vehicle Configuration menu' select from the menu 'Special Applications'.
7 . From the 'Special Applications' menu select 'Network Integrity Test'.
8 . From the 'Network Integrity Test' read out record all software versions.
9 . Then from the 'Vehicle Configuration menu' select from the menu 'Module Programming'.
10 . Select from the menu 'Configure existing modules'.
11 . From the menu select 'Audio Front Control Module' (if installed) from the drop down menu press 'tick' to continue.
12 . Follow all on-screen instructions to complete this task.
13 . From the menu select 'Audio Amplifier Module' (if installed) from the drop down menu press 'tick' to continue.
14 . Follow all on-screen instructions to complete this task.
15 . From the menu select 'Cellular Telephone Module' (if installed) from the drop down menu press 'tick' to continue.
16 . Follow all on-screen instructions to complete this task.
17 . From the menu select 'Traffic Message Channel Module' (if installed) from the drop down menu press 'tick' to continue.
18 . Follow all on-screen instructions to complete this task.
19 . From the menu select 'Television Module' (if installed) from the drop down menu press 'tick' to continue.
20 . Follow all on-screen instructions to complete this task.
21 . From the menu select 'Rear Entertainment Control Module' (if installed) from the drop down menu press 'tick' to continue.
22 . Follow all on-screen instructions to complete this task.
23 . Then from the 'Vehicle Configuration menu' Select from the menu 'Set-up and Configuration'.
24 . NOTE: Do NOT program the HLDF as part of this routine.
From the 'Set-up and Configuration' menu select 'Navigation System'.
25 . Then select 'Enable the destination entry on the move'.
26 . Follow all on-screen instructions to complete this task.
27 . When all the modules have been configured please run 'DTC monitor' and read and clear all DTCs.
28 . When the task is completed, exit the current session.
29 . Disconnect IDS and the battery charger/power supply.
Post #5988 3rd Jun 2009 1:28pm
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
An OBD Scanner will not do this, you require something along the lines of a Black Box MSV or similar. I'm sure BBS wil be along shortly Laughing , if not Google Black Box Solutions.
Ivan[/quote] FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #6024 4th Jun 2009 6:04pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
I can't remember how and what you do, but there is an area on the screen that you hold and it brings up a code entry, will try and dig out my notes. letters not necessarily in the right order
Post #6027 4th Jun 2009 9:32pm
I seem to recall something like pressing on the centre top of the screen for about ten seconds brings up some secret menu, first read it on the RRSport forum. Discovery 4 HSE
Post #6036 5th Jun 2009 11:04am
Just found this, not read it or tried it but thought you may want to see it:
http://www.rrsport.co.uk/forum/topic2102.h...ecret+menu Discovery 4 HSE
Post #6037 5th Jun 2009 11:05am
Vogue
the 1791 code does work on a FFRR, but was disabled by Land Rover on 2007 or 2008 MY.
Post #6038 5th Jun 2009 1:13pm
What about 754 as a code? Discovery 4 HSE
Post #6042 5th Jun 2009 3:04pm
Tried it on mine, couldn't access the secret menu but that could be because I upgraded my sat nav to a 2009 disc and perhaps it was locked down by then. Discovery 4 HSE
Post #6043 5th Jun 2009 4:07pm
Dixy
Thats the one, works in my FF letters not necessarily in the right order
Post #6045 5th Jun 2009 6:46pm
Tried it on mine, No secret Menu. Whistle
Post #6048 5th Jun 2009 7:02pm
pyramid1235
Thanks, i can get the secret menu up and use code 1791 from the navigation page to enter on the move also i have entered code 753 which allows some other functions, self check and a few other tests just wondered if any of the avalable readers would allow me to enable it permenently!! Im assuming everybody knows which page and where to hold there screen to get to these functions? just in case on mine i from the mappage press menu in bottom left corner, then on the next screen press and hold the top edge of the screen in the centre for approx 10 - 20 seconds this will then bring up the page that requests you to enter the codes, 1791 for full use of sat nav on the move and 753 for diagnostics, does anyone know any other codes and what they do???? Very Happy Thumbs Up
Post #6060 6th Jun 2009 5:50pm
Vogue
Hi Adam, the upgraded sat nav disc unfortunately disables the 1791 function, I don't know of a way round it.
Post #6066 7th Jun 2009 8:02pm
I know, TBH, i can't think of a time when I have wanted to input on the move. I think having ALL funtions enabled on the move would be better and ALL of the time, not just when you access a code screen, which sounds like it could be pretty offputting while driving! Discovery 4 HSE
Post #6067 7th Jun 2009 9:55pm
Vogue
Yes agreed, it was a hastle going through the codes (for a passenger Wink ), but useful say if you were on a Motorway en route and needed to enter a post code or address to alter your route and were unable to stop.
Post #6070 8th Jun 2009 10:11am
Of course you all do have destination on the move , relay useful things like home or any other pre-set destinations that you know well . Very useful when you are too drunk to remember Shocked Whistle 2008 MY Supercharged
Post #6071 8th Jun 2009 2:15pm
