Home > In Car Electronics (L322) > Best Arial
comports
Best Arial
So whats the best Digital TV arial for your car..?
I got one of these (http://www.ebay.co.uk/itm/Car-Freeview-Dig...8516934889) and it's ok but not great..!
Fitted to the read side window. Should I get anther and place on the other rear window and wire them in together or upgrade to a better one.?
Thoughts.? Ash
2016 SDV8 AB
Post #89242 27th Oct 2011 10:22pm
is not your existing antenna ok, it is pretty good especially having both vertical and horizontal polarisation..
btw if you have after market tints and they are not carbon type ,then that will restrict reception, and dont expect to much when mobile cos that signal will dip and dive as you drive... ... - .- -.
Post #89263 28th Oct 2011 9:49am
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
you might want to consider a higher db rating, your is a 25 db. Range rover td6 54 reg touch screen
Post #89288 28th Oct 2011 12:58pm
