Home > General > New Range Rover owner
Page 3 of 5 <12345>
supershuttle
I think owning a FFRR is an enjoyable journey which will never end however the fare in first class is always high, welcome to our world Very Happy Geoff
Post #89266 28th Oct 2011 9:54am
A1GSS
supershuttle wrote:
FWIW if mine is flashing it generally means it ain't working. I press the on button on the remote until the green led glows constantly and then release it, at which point the green led goes out
However given the rich tapestry of variation in FF behaviour that may not mean anything, but it's just what happens to me.
Turning off is the same if I do it remotely only its obviously the off button and the red led HTH
OK, understood... but: - if you do this, does it then reset it? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #89313 28th Oct 2011 2:50pm
supershuttle
I'm easily confused and so your question has confused me. Confused
I don't quite understand what you're getting at - I have never had any thing to do other than press on until the green led is on constantly - heater on and I either just get in car and go after about 20 minutes in which case it switches off, or I press off if i haven't finished by brekky but think it's been on long enough in which case red led lights up and heater goes off.
I'm probably being a bit thick but - press on,led green, heater on/ press off,led red, heater off - led only lights whilst button on remote is being pressed this i'm afraid is the limit of my experience. Crying or Very sad Geoff
Post #89326 28th Oct 2011 5:19pm
A1GSS
Ahah. Maybe I didn't read the manual.. do you have to press and hold?
If I press the "on" button briefly, the fans start but not the heater, then it all turns off. I assumed it's broken.
Give me a few mins, test in progress Graham
____
Post #89330 28th Oct 2011 6:21pm
A1GSS
Right, tried again. Makes no difference if I "press and hold" or "press and let go"... I get a green "on" light on teh remote after a second or so, it doesn't flash. Maybe I read too much into your post, sorry.
Mine's still broke. Big Cry
I do have my IIDTool on the way though so I'll be able to see if there are any faults and maybe even clear them... Graham
____
Post #89333 28th Oct 2011 6:44pm
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
hi green, give the lads a call at worldwide LR in birkdale (sandon road) top fellas, reasonable rates and always done me proud
Post #89340 28th Oct 2011 7:51pm
Green
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Is that for parts? Do they service as well?
Fault number 2 occurred at 1750 today 'air suspension inactive' whilst driving down the motorway!!!
Post #89348 28th Oct 2011 9:34pm
Green
Sorry guys.
The 'Air Susp Inactive' seemed to clear when I pulled out of the car parking space at Ikea.
However, driving down the motorway today and it did the same again!!! It seemed to happen yesterday and today around 5 minutes into motorway driving.
Also, it might be me but someone at work wanted to look at my car so I was only too happy to oblige. I raised the suspension to 'normal' from access, it took maybe 15 seconds, no noise, no problems. But then I raised it to Off Road. We could hear what sounded to us like a knocking/banging and it took around 45 seconds to raise. Should I be worried cos I tell you, i'm starting to panic!!!
It did get a new battery before the car was handed over to me. I'm expecting the dealer knows about the steering remedy (left/right).
Post #89417 29th Oct 2011 5:44pm
Green wrote:
.......However, driving down the motorway today and it did the same again!!! It seemed to happen yesterday and today around 5 minutes into motorway driving.
This could be speed related or the steering angle sensor might be out or faulty, is the steering wheel straight?.....
Green wrote:
.................We could hear what sounded to us like a knocking/banging and it took around 45 seconds to raise.
Where was the noise coming from? was it from the suspension area (one of the 4 corners) or the compressor area (boot)
Not yet, wait until you have to pay for the repairs Rolling with laughter Rolling with laughter
I'm sure they did know
Post #89435 29th Oct 2011 6:50pm
Green
Hello mate
From what I can remember, the steering wheel was/is straight!
The noise sounded to me like it was coming from the front of the car and if you pushed me i'd say it sounded worse on the O/S/F!
Post #89440 29th Oct 2011 7:11pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Seems that 45 seconds is a long time to raise.
I can only go by mine as a new one, but only takes about 3 to 5 seconds.
I think noise (as long as not too loud) is relatively normal. Especially if you're rasing or lowering stationary and particulary with brake on.
Even my new one creaks a bit if you do that. I tend to only raise & lower when coming to a crawl - that way everthing can move as it needs to without forcing anything, so no noises.
I would get that checked though as that does seem way to long to lift it.
Crying or Very sad
Post #89630 31st Oct 2011 9:07am
Green
Thanks mate.
I've just had the "Air Susp Inactive" message again just as I was driving up my drive. Thought that i'd just park up and leave it but the car has reminded me that its not level as the alarm started going off!! Sad
Emailed the dealer yesterday but not heard from them yet!
Post #89710 31st Oct 2011 5:30pm
Rolo
good luck Thumbs Up hope it's not too expensive to fix
Post #89840 1st Nov 2011 11:41am
Green
Cheers Rolo,
I'm not expecting to pay anything.
I've had the car 5 days and the fault occurred the day after I bought the car. I had also raised a suspension fault prior to buying the car and was assured it would be rectified. So, according to Consumer Direct/Trading Standards the dealer should be repairing the faults.
Today brought a new angle to the problems. Driving to work again, just joined the motorway (still accelerating) display showed OFF ROAD HEIGHT MAX SPEED 30 MPH. Marvellous. Couldn't do anything (in Lane 2) so accelerate and then it changed to 'AIR SUSP INACTIVE which stayed on for the rest of my journey. Parked it up at work and came back to it hours later. Did the same old stuff on the way home from work!
I remember driving a Range Rover a few years ago and I remember it feeling like travelling on a flying carpet. What i'm finding is that every bump in the road is felt in the car!
Post #89878 1st Nov 2011 4:56pm
Green
Car is booked in for Tuesday. Strangely though, my remote parking heater started working earlier!! I wonder why it wouldn't work the other day but it did today!?
I'm also noticing little things on the car that I want to replace/clean etc! I'm spending hundreds in my head and whilst i've only spent a few quid with Dan so far, I can see that I may as well ask him to retain my cards! Laughing
Post #90340 4th Nov 2011 1:54pm
Page 3 of 5 <12345>
