Home > Technical (L322) > Heating Fault
drakes
Heating Fault
I have a strange fault with the heater. If you put the temp dial to min then the fan speeds up and blasts out icy cold air, if you then set the temp somewhere in the middle the fan slows down as you would expect however when you set the temp to max although hot air comes out the fan does not speed up so you are only getting a small air flow. The rear heater out put remains cold at all temp settings except max.
Any suggestions greatfully recieved.
I have tried searching but can't seem to find anything that specific about the heating system. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #84536 29th Sep 2011 8:06am
search for "final stage resistor" ,with quotation marks. Wink ... - .- -.
Post #84539 29th Sep 2011 8:15am
drakes
I have read about the final stage resistor but that seems to be the problem if the fan stops working, my fan works fine if you set the temp to min, only once you take the temp setting off min does the fan slow down. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #84543 29th Sep 2011 8:30am
agreed but in some of those threads it does talk about problems similar to yours.. ... - .- -.
Post #84545 29th Sep 2011 8:35am
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
the small air grill beside the knobs is clean or full of dust? XJC, RRV8, Series1 86 and 107% of real pleasure
Post #84741 30th Sep 2011 11:19am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
+1 Thumbs Up
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #84824 30th Sep 2011 7:59pm
drakes
I have read the FSR threads and it would appear that before the FSR packs up completely it starts to cause problems at higher temps rather than lower temps. Would those of you that have suffered from probs with the FSR agree with this and think that I am getting a pre warning of a failure, if this is the case I shall change it before it does fail. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #84914 1st Oct 2011 6:29pm
