![]() | Home > In Car Electronics (L322) > vogue se rear screens |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
i sure someone asked this recently, have a search mate..can you update your car profile as well please.. ... - .- -.
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Yes it was asked the other day and I think the response was that there is a fibre optic cable that can break in the seat?
barrieeld Member Since: 07 Dec 2010 Location: Scotland Posts: 260 ![]() |
Does anyone know the procedure for getting this cable exposed for testing? |
If you take the back off your seat (one hidden torx screw each side at the bottom) then lift the rear up and towards the back seat you will expose the electrics, you will see a black plug with a triangular shaped connector about the thickness of your little finger. Then under the front of the seat you will see a much larger black connector with a black plastic holder (to stop it coming apart with the forward/backward movement of the chair) thats the other end to disconnect. (buy please trace the wire to it so as not to disconnect the wrong wire!) It is a ten min job! eeek!
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
There's no fibre optic cable to the RSE screens ![]() I retro fitted the full factory RSE system to my wifes D3 ![]() Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
