![]() | Home > Technical (L322) > After market reverse camera |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
have you got a link for that as id like one for the number plate light area also did you check yet to see if it fits "RANGEISM WILL NOT BE TOLERATED"
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/Reverse-Camera-L...8728wt_902
Thought they were for the Sport as the FF'S are at the top of the tailgate ….. |
finlander Member Since: 12 Oct 2011 Location: bradwell on sea Posts: 4 ![]() ![]() ![]() |
can you let me know how you got on and if it all works as I am thinking of adding this to mine
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi, i would like to know if you get it to fit as it looks similar to the one i bought a while ago, it was from a different seller.
did you order NTSC..
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
I'm interested too, Have a MY05 TD6 HSE with touch screen radio. No TV, Phone or SAT-NAV. Will it work without TV.
when you say it has no tv but you have a touch screen fitted, was that a retro fit... V8 facelift Range Rover Autobiography 22" wheels.
Only had RR a few months . But believe touch screen is original
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
on the back of the touch screen there are 3 inputs...you can connect a camera to one and get the it activated by accessing the CCF via a faultmate or similar.. edit...rear of screen.. Last edited by stan on 21st Nov 2011 3:44pm. Edited 1 time in total |
gary, so in your boot do you not have the tv module. beside that the touch screen still has the av in port so yes you could put the rev cam on V8 facelift Range Rover Autobiography 22" wheels.
Big thanks to Stan & Daveo.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3873 ![]() ![]() ![]() |
I don't want to hijack the thread, in fact you can have it back in a minute, but it seems that there is a lot of rear camera expertise here that might be able to answer a simple question. I have a 2007MY FF and of course that has a reverse cam at the top of the tailgate - it works - BUT the quality isn't that great and I think that may be normal.
geoff,
