Home > In Car Electronics (L322) > Emergency help! - Can't turn radio off or it will buzz loud!
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
I just arrived at work 10min ago
Turned the engine off, then the speakers went crazy!
Turned the radio on, all is fine... Turned the radio off again and the speakers go mad again.. the noise is of a fairly loud buzzing, like an electric motor connected in series to a battery and speaker.
Seems to be coming from the front centre speaker...
I left the car unlocked with the radio on and volume at 0 but I assume after 45 min it will start again?
Any fuses I can pull? Haven't got any tools on me so a quick diy job is impossible.
Ironic really as it's going to a specialist tomorrow to get other stuff sorted out..
All joys of range rover ownership Rolling with laughter
Post #79296 5th Sep 2011 10:13am
dan_uk_1984
Unplug amp in boot...
Post #79297 5th Sep 2011 10:17am
reason for radio mayhem could be water ingress, solution is what dan said or dis-connect battery to see if it resets itself..
Post #79300 5th Sep 2011 10:26am
mrd1990
Thanks guys!
Shall try that now! Water ingress seems likely as it's been raining all night and morning in North Censored Wales Sheep
Edit: That fixed it! - Hugely appreciated guys! Thumbs Up
The amp and cables were soaked, unplugged the amp and the silance again.
Looks like a job for the weekend!
thanks again
Post #79302 5th Sep 2011 10:33am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
I need to do this as well Confused
Can someone tell me how to get the D pillow cover off. Ive tried to prise it off but it felt like I was going to snap/break it.
Does it just pull off or are there screws holding it in place.
Cheers Grant
Post #79352 5th Sep 2011 5:00pm
which ones the D pillar? Shocked [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #79631 6th Sep 2011 9:17pm
Bob the B
Is that not the one at the rear corner of the car? Embarassed
Post #79658 7th Sep 2011 12:29am
