![]() | Home > Technical (L322) > P1247 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
The fault code P1247 on a Range Rover L322 indicates that the turbo boost pressure is too low. This can lead to slow acceleration and restricted performance. Common causes include air leaks in the turbo boost pressure system, such as damaged hoses or a leaking intake manifold.
Blueyv8 Member Since: 14 Apr 2025 Location: Suffolk Posts: 3 ![]() ![]() ![]() |
I’ve changed the four house to silicone still same issue now waiting to do a smoke test have seen the plenums can split bit annoying |
The air instake hose ( throttle body end ) usually needs looking at, I had to do mine with three extra o rings, hundreds of us on the forum have had to look at this area first as it easily gets loose, suggest a
Cheers mate funny you say that where the hose goes onto the body with that spring clip does seem loose |
