![]() | Home > Maintenance & Mods (L322) > Heater won't get interior above 22 degrees |
Else Member Since: 02 Oct 2023 Location: Essex Posts: 7 ![]() ![]() |
Pictures here
Roverlander Member Since: 16 Nov 2018 Location: Las Vegas Posts: 8 ![]() ![]() ![]() |
It could be a faulty thermostat. There's a rubber seal that comes off and gets wedged in the thermostat that holds it open, not allowing or slowing it's way to the proper running temp. I've had it happen in a very cold environment (-10° F) and my cab wouldn't heat up....
Morning all.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1306 ![]() ![]() ![]() |
Did it work OK before you changed the coolant? |
I hadn’t tried turning the heat up prior to draining and refilling the coolant so it’s possible this fault has been there all along. I have ordered a new changeover valve in case the existing valve is faulty after all. |
When I refilled my coolant, I filled the expansion tank to max first and then got a small funnel in the bleed screw on the hose and got another litre of coolant in.
All done, working as it should at last, it was the changeover valve.
Nice one. Is that the one on the drivers side for the fbh?
Yes, thats the one, bolted to the offside inner wing just below the fusebox. |
