Home > Technical (L322) > Today's problem, central locking
dingg1
Today I clipped my phone to the vent on the dashboard, in doing so I locked/unlocked the car from the button on the dash quite a few times fitting the phone holder, anyways gets to my destination and low and behold central locking from the fob has stopped working, central locking still works from manually using the key in the door, alarm still sounds on locking and unlocking.
Any ideas chaps?
Scanned for faults but nothing specific showing
Post #715778 8th Apr 2025 7:52pm
mjdronfield
Could be wrong, but doesn’t it ignore the fob if the car is locked and unlocked so many times in quick succession? For a length of time? Thought I’d read it somewhere. Like if it’s being pressed accidentally in your pocket…. I know it’s the switch you pressed but could be similar….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #715781 8th Apr 2025 8:58pm
mjdronfield
Sometimes I surprise even myself 🤣 knew I’d read something…
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #715782 8th Apr 2025 9:06pm
dingg1
Cheers, that's something to look at, do you have a link to the text you uploaded?
Tia👍
Post #715784 8th Apr 2025 9:39pm
mjdronfield
It’s from the Workshop Manual, downloadable from the Wiki, top right under the fullfatrr banner.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #715785 8th Apr 2025 9:47pm
mjdronfield
It’s the 2011 workshop manual, but I’m sure earlier cars were the same. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #715786 8th Apr 2025 9:48pm
Varks74
i believe the antenna for the remote central locking is protected by a fuse in the rear fuse box, it also controls the glove box actuators, so try the button, if it works then its not the fuse, if it doesn't unlock the glove box, then it is probably the fuse, when mine did it i think i had to re-sync the remote to the BCM, only took a few seconds to sort,
Post #715805 9th Apr 2025 8:05am
dingg1
Well it's decided to fix itself, all working as normal this morning, maybe it just needed a good nights kip 🤔
Post #715821 9th Apr 2025 10:49am
mjdronfield
That will have been the repetitive blocking then.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #715823 9th Apr 2025 11:07am
