Home > Wheels & Tyres > 22 inch tyres
sshenton1975
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
22 inch tyres
Hi all
Can i run 285 40 or even 45 x 22 ?
Id like a bit more sidewall
Thanks
Post #715756 8th Apr 2025 10:25am
read the thread just below this one..... ... - .- -.
Post #715758 8th Apr 2025 10:52am
Vogue
285/40/22 fit fine with absolutely no rubbing issues, they are the closest to the original rolling radius as OEM fit. I have run these on 2x L405’s and also 285/50/20 in the winter with AT’s on.
If you go up an aspect ratio size to 285/45/22 you may experience rubbing and you will also raise the gearing which will dull acceleration depending on which engine you have.
Many in the states run 285/45/22 as these are also standard fit on some yank 4x4’s. Their 405 engines tend to be the higher output V8’s 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #715777 8th Apr 2025 6:38pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I am running 285/45R22 and can only say that I love them. No issues with rubbing etc but you may do if you were to go for off road tyres, but not with standard road tyres.
I think they are the perfect size - sidewall but still responsive, fill the arches, good ride characteristics, readily available as a standard size (standard fit on L460 so can get LR OEM fitment).
In terms of gearing, I have a TDV6 and not noticed any negative effects in terms of acceleration etc. there is more than enough torque to handle a slightly larger tyre.
Post #715869 9th Apr 2025 11:34pm
