Home > Technical (L322) > Getting error after replacing intake cover
RediH
Canada
I just replaced the right valve cover on my 2016 RR SPORT TD6, and now it is showing me P0088—Fuel rail system pressure too high. The car doesn't have power over 2500 rpm and starts to work roughly. It starts and drives smoothly at low rpm. I replaced the return fuel line as well. I cleaned the fuel rail sensor. Any idea what I should check or what may go wrong during the installation?
Thank you in advance
Post #715685 7th Apr 2025 2:45am
RediH
Canada
Ps: if it drives below 3000 rpm doesn't show check engine light on, more then that shows restriction performance. I already checked for any air leak with smoke test. It's ok
Post #715686 7th Apr 2025 2:47am
This forum is for "Full Fat" Range Rover you need
https://www.rrsport.co.uk/forum/index.php
for the Sport... Pete
Post #715708 7th Apr 2025 2:08pm
RediH
Canada
I have to post it in another forum?
Post #715729 7th Apr 2025 6:57pm
