Whilst I dont have a 5.0SC, my experience of all the V8's i've had before ( 3.5, 3.9, 4.0, 4.2SC, 4.4) is that they have all had no issue with getting up to temperature ... as engines in general, petrol V8's just dont run cool by themselves. As far as a I know, the thermostat should regulate at 95degC at factory spec and that some have fitted an 85degC replacement. So if you're not getting upto operating temp, then its being over-cooled, which really can only come from the radiator doing the cooling ... which is fed by the thermostat.
So, my guess is that the thermostat is stuck open and feeding the radiator too much and cooling too much, and I would replace it as the first port of call.
Do you know where the second temp sensor is located ? I'm guessing it might be radiator outlet temp or something similar? ( It starts at 11degC ... which is possible the ambient temp at time ? ) V8 or else ...
