Home > Technical (L322) > over run noise tdv8 4.4 2011
miketrike
United Kingdom 2011 Range Rover SE TDV8 Baltic Blue
Hi all my car is not as quiet as normal..its a very low sounding grrrr which dissipates after about 10 -20 mins of driving ..its not engine related ..and as i say only for first 5miles of driving or should isay i cant really detect inside car after this short drive... ive got it booked in for next tuesday any body had this ?im sure its something power train related no noise when stopped oh should add noise goes away on acceleration and returns at over run i ve checked all oil levels all good
Post #715041 28th Mar 2025 11:34am
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Tyres maybe? I had similar with my tyres a few weeks ago, changed them and noise is gone. When the old tyres were removed, Found a bulge on the inside. Check pressures and tread for uneven wear. Hopefully a cheap and cheerful fix. Either that or centre prop bearing wearing out, quite common on the 4.4 TDV8.
Post #715075 28th Mar 2025 7:58pm
miketrike
Hi and thanks for reply ..never considered tyres ...i ll get them checked ...i was coming to conclusion that my noise could be rear bearing transfer case ..but your centre bearing idea maybe first port of call..its make me mind up time..been trying find some one who can raise four wheels to do stethescope test on said parts but hens teeth comes to mind thanks again Mike
Post #715264 31st Mar 2025 12:37pm
Barmybrummie
Hiya mike that's ok, where in Brum are you? There's a few Indies in the Midlands that would help diagnose the centre prop bearing. I'm sure if you raise the suspension and leave a door open, crawl underneath and see if you have play in the bearing. But like you say the noise disappears after a bit of driving, the tyres would have warmed up and noise then goes. Saab 9-5's were notorious for road noise when wearing down and pressures, if you got cheap Chinese tyres on or budget, that could be the culprit.
Post #715273 31st Mar 2025 3:04pm
miketrike
hi barry im in kingswinford ..ill be raising motor up this after noon im going to put on four big wooden blocks with suspension locked down ..my sons coming to get under and large scredriver as listening device..ill let you know if i find problem..these low vibration jobs always a nightmare my sons 3.6 08 is much quieter inside cab than my 2011 tdv8...thanks again for input Mike
Post #715409 2nd Apr 2025 11:44am
Barmybrummie
Hey Mike there a few Indies around that way. You've got coseley 4x4 and also oval autos, all with good reviews.
Just be careful with the suspension in off road height and crawling underneath just in case it decides to lower itself, leave a door open.
Post #715447 2nd Apr 2025 8:36pm
