Interesting Steve k
Only saying i assume the '0xBD EBV function fault received from ABS ECU' fault is a legacy fault and not to be concerned about as on another RR forum ( landyzone, poster called Saint.V8 ), one of the resident experts says on 2002-2005 its an old fault code carried over from the BMW days.
Think I've also read it on here a few times too
If i turn the ride height knob, the new height flashes, but the height doesn't adjust. the LED just keeps flashing as though its adjusting.
It does feel as though something has locked/latched it out of operation.
Strange for all 4 ABS sensors to not be giving me a live value when driving slowly, but could this be locked out because of the EAS not responding?
I think I'm going to try a battery disconnect first then manually lowering the suspension by cracking off one of the valve blocks to see if it'll reset and inflate/deflate.
After that, I'm guessing look at ABS sensors, unsure if one not working will hold all 4 off from live values
