![]() | Home > Technical (L322) > Tdv8 4.4 restricted performance diagnosis |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3803 ![]() ![]() ![]() |
If the CSOV isn’t opening Iwould be looking for damage on the vacuum pipes, not a wiring problem?
Monty400k Member Since: 21 Oct 2019 Location: Glasgow Posts: 12 ![]() ![]() ![]() |
I've been through the vaccuam system, found some collapsed lines which I replaced, independent specialist claim that the fault code point towards an electrical fault, they weren't aware of the belt failure so have no reason to doubt them. Smoke test would be the only way to definitely check vaccuam system I assume? |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 223 ![]() ![]() |
Do you have the fault code(s)? 2012 Vogue TDV8 in Aintree green over sand |
P0033-00
I also had PO33-00 (2F) code showing for ages before I found the cause to be a dislodged plug on the wiring.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
I've read your thread, the plug is connected, although I suspect that is the connector with the damaged wire due to its location in relation to the belt, if I could test the connector for voltage etc it means I could rule it out |
Cheers, I will just add, even with the plug disconnected it definitely didn’t cause any R P problems.
Good to know, thanks |
