![]() | Home > Maintenance & Mods (L405) > Boot won't auto open. |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 72 ![]() ![]() ![]() |
This is more than likely to be a battery problem. Worth putting on charge overrnight. (Terminals under bonnet).
neil3728 Member Since: 24 Feb 2020 Location: Howden Posts: 57 ![]() ![]() ![]() |
Thank you for the reply.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8496 ![]() ![]() ![]() |
IIRC you need a 10mm socket, preferably a long one...
It’s an easy job, 10 minutes max to get to battery, carefully lifting aside the suspension compressor.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7993 ![]() ![]() ![]() |
L405 battery thread - https://www.fullfatrr.com/forum/topic65160.html |
Many thanks everyone, I have to pop to Halfords on Saturday anyway so might see if they can change the battery while I'm there.
Small update,
Just guessing and changing bits can end up costing a lot and you still have the problem...
I have to have a look for a Gap IID tool.
hmallett Member Since: 21 Jan 2024 Location: Mid-Wales Posts: 112 ![]() ![]() ![]() |
It might be worth considering the Autel AP200. It is not as full featured, or as pretty as the GAP IID tool, but it can read the codes.
Might be a daft question..but have you also done a boot reset?
