Home > In Car Electronics (L322) > BCM reset soild state driver output for rear interior light
Big E
United Kingdom 2012 Range Rover Westminster TDV8 Barolo Black
Help please.
The solid state driver protection has activated for the rear interior light and won't reset after I have cleared the short circuit.
I know it's only a minor fault but it's driving me mad.
I have tried everything I can to clear the fault including disconnecting the battery for 15 minutes (and shorting out the wires) and using the iidtool (G2) to perform a "soft reset" of all the ECUs.
There was a short circuit on the front map reading light (one of the cut-able links was touching ground) but I have repaired this and replaced the fuse (57).
I am fairly confident that this short is what caused the solid state drive protection to activate (it would short the driver output when the rear interior light switch was on and the door was opened)
All the interior lights are now working fine except that the rear interior light does not come on when the door is opened (it works fine with the switch).
I have consulted the wiring diagram (from the wiki) and have tested the wire from the BCM ( C0580-1 ) to the interior rear light ( C0357-8 ) for short circuits to ground by using a multimeter (on 20k ohms range). I tested this at the rear interior light with it still plugged in and the circuit was completely clear (open circuit).
I have read that the dealer can "enable protected circuits" with the JLR SSD or Pathfinder software and i have also read that the iidtool can also do it but i can't find this function anywhere in the menu.Is this correct ?
I would have thought that a "soft reset" via the iidtool or disconnecting the battery would do the same thing anyway but I am not sure.Does any know if it should or not ?
I now suspect that this particular output from the BCM has blown and I am just going to have to live with it (and the knowledge that my car is not fault free) or fork out for a new (or used) BCM
Any help or ideas on what to try next would be highly appreciated
FAULT LIST
VIN SALLMAMJ3CA381224
Model L322 - Range Rover 2012
Vehicle scanned on 15 Mar 2025 12:27:08
IIDControl 4.2.11 Build 168 Android - IIDTool BT V3.0 B2803
BCM-Body Control
U1000-00 - Solid state driver protection activated - Driver disabled (2F)
( on 15-03-2025 12:26:37 at 130388 mi )
U3000-49 - Control module - System internal failure - internal electronic failure (2F)
B109D-11 - Rear courtesy lamp - General electrical failure - circuit short to ground (2F)
Post #714155 16th Mar 2025 8:13am
