![]() | Home > Maintenance & Mods (L322) > FSR headscratcher |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Just done one in my 2011 and it was triangular. |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 115 ![]() ![]() ![]() |
Smashing - thanks Kev. That's a relief ! To be fair, I wouldn't have known without taking out the old one, so maybe a lesson there in that the rectangular ones aren't always fitted to the later cars and if in doubt, check before ordering. |
ashtrucker Member Since: 30 Jan 2012 Location: lincoln Posts: 43 ![]() ![]() ![]() |
I could be wrong but i think I read in one of the other threads you can just cut the pins off the new one to fit the triangle hole the old one came out of because it’s just a heat sinc no internal wiring or anything 2012 Westminster 4.4 tdv8 |
Easier to just send the wrong one back I think. Knowing my luck I'd cut off the wrong pins, or it would be a faulty unit when installed.
I said I wouldn't fit a pattern one but genuine ones are very expensive. Next day from Amazon for £21.67!!
Went for the same - £20.99 delivered tomorrow. If it doesn't work I'll send it back FOC but at least it means I can get it in tomorrow or Friday. Got a couple of days hols to use up, so doing the head unit swapper to dual view and blower motor at the same time, so should be fun ! |
I did mine last November (2024) with a cheap Amazon part still going strong so far fingers crossed 2012 Westminster 4.4 tdv8 |
