Home > Maintenance & Mods (L405) > Flickering dash ABS, skid, start-stop, speedo while driving
mike2013
Hello, I'd appreciate any thoughts on this please:
It's a strange issue: while driving, I'm getting an intermittent flickering of several dashboard warnings - including skid control and ABS, together with the resetting of the start/stop off (I usually keep it off, but when this happens it resets back on again), together with the headlamps themselves visibly flickering.
The whole thing lasts about 1-2 seconds each time, and happens every few minutes or so while driving.
At the same time, the (virtual) speedo needle suddenly drops to zero (which looks very disconcerting) but instantly picks back up to the correct speed reading once the "funny turn" is over.
The performance and engine power is unaffected - so I'm wondering about a dodgy connection or grounding issue? The battery is fine, and I changed it about a year ago.
By the way, this is in a 4.4stdv8 L405 vogue SE 2015/2016 model.
Any pointers about where to look first would be gratefully received!!
Mike -- .. -.- .
L405 2016 4.4 SDV8 SE
Evoque 2016 2.0d HSE
L322 2010 4.4 TDV8 SE
Freelander 2 2009 HSE
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #713515 7th Mar 2025 7:38pm
mpirie
I'd suggest starting by checking the earthing points under the front offside wheel arch liner.
Seems to be a common weakness when electrical gremlins appear.
Mike
Post #713519 7th Mar 2025 8:07pm
mike2013
Thanks Mike. That's a good idea. That area is a PITA to access though... but will give it a try!
Thanks again,
Mike -- .. -.- .
L405 2015 4.4 SDV8
L322 2005 2.9 TD6
P38 2000 2.5 DSE
Post #713520 7th Mar 2025 8:13pm
Merchy
The below you tube video should be handy for you. Also - look in the wiki section, plus a search of posts will reveal a lot more info on this topic.
I may be wrong but I seem to remember reading about an earth point in one of the front footwells ?
https://www.google.com/url?esrc=s&q=&a..._aur-W0KSV
Post #713532 7th Mar 2025 10:15pm
Mikey
VERY common Laughing
Post #713538 7th Mar 2025 10:47pm
