![]() | Home > Technical (L322) > Smart Key not recognised on 2011 L322 |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 70 ![]() ![]() ![]() |
If you have key cover with your insurance get them the come out. They should give you a new key and code it to the car. If you only have one key the car would have come with 2 originally, so you. Like end up with 2 new keys. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 899 ![]() ![]() ![]() |
Appreciate it sounds obvious but check you have the new battery in the key the correct way up, as it can go in both ways - ask me how I know! |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 332 ![]() ![]() |
It sounds like you have bigger issues, but the firm recommendation has always been to use Duracell batteries in the fobs as other batteries, including Energiser, don't always work properly for L322s
Pigglet Member Since: 26 Feb 2025 Location: North East Posts: 4 ![]() ![]() |
Thanks for the replies guys. Unfortunately the vehicle is no longer insured as it has been off the road for 18 months or so.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Also check there is no clear film on the battery it’s easily missed! 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Jimmy86 Member Since: 27 Feb 2024 Location: East midlands Posts: 19 ![]() ![]() |
I occasionally get this message if the 12v battery is running low. Is your 12v battery OK? |
I didn't notice a film on the battery but I will check, thanks for the suggestion!
