Home > Technical (L322) > Early L322 front L and R height sensor part numbers
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, I've tried to search on here, and checked LRcat but I cant speak Russian, and don't really understand the translated version either. Big Cry
Can anyone please tell me the part numbers for both LH and RH height sensors for my 2003 TD6. May as well replace them both while I am doing the rears.
Thanks all
Post #713458 7th Mar 2025 1:24am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
If you go to the sponsors page, AF Factors, under L322, suspension parts, look for the "height sensors to VIN4A174107" page, the graphic shows the part numbers for early models.
If your's is after that VIN other sections can help you with those part numbers.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #713463 7th Mar 2025 8:50am
