Home > Technical (L322) > Leak off pipes 3.6L TDV8 - any pointers on type ?
nick4275
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
An easy one I hope.
After changing head gaskets a year or so ago I had to replace a couple of the leak off pipes on the injectors that got broken off.
I used what I think is the proper pipe to fix it but obviously not as 3 times now the replaced pipes have split (being eaten by the diesel I assume).
Anyone know where I can get a metre of decent quality pipe that wont get eaten by diesel ?
Many Thanks Previous life - 2012 L320 SDV6 - Got divorced, say no more!
Previous life - 2014 L494 SDV6 - Got nicked, without keys, watched it go !
The Duchess - 2007 L322 TDV8 3.6 Autobiography with 270K miles on the clock
The Bonkers One - Audi SQ7 V8 4L TT - It will pull your face off.
Post #713287 4th Mar 2025 12:15pm
Merchy
Found this on the web as an example, they sell by the metre as well, see link below...
https://siliconehoseuk.co.uk/collections/r...-Gd5cCZjOR
Please note, I do not have any connections with the company mentioned as an example.
Post #713290 4th Mar 2025 1:25pm
wayneg
https://www.aliexpress.com/item/1005007512...ry_from%3A
Or 174 pounds from Britcar 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #713340 5th Mar 2025 3:28am
