![]() | Home > Technical (L405) > vehicle lean when cornering fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8490 ![]() ![]() ![]() |
Sounds like leaking ACE pipes, the car is measuring a drop in line pressure, you will probably have low fluid in the tank and a leak dripping somewhere....
bigdave Site Sponsor Member Since: 27 Jun 2011 Location: Cornwall Posts: 221 ![]() ![]() ![]() |
Sounds exactly what i had and turned out to be leaking front ACE pipes.
TST717 Member Since: 18 Oct 2014 Location: Inverness Posts: 35 ![]() ![]() |
I had similar issue having gone over a small speed bump in Tesco car park ….had to replace the ACE valve block located below the drivers side door area
