![]() | Home > In Car Electronics (L405) > IIDool BT version on MY21.5 L405 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35588 ![]() ![]() |
looked into this for my 21my and it seems it has to be a G4...
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2622 ![]() ![]() |
Thanks Stan. Their website wasn't very informative but I suppose if my BT can't be used even to read faults then I'll have to get the G4 and wait for ipdates to make it more useful. |
you could try your BT and see if you get anything.... ... - .- -.
That's the plan.
Unfortunately not, it's a bit to expensive for me. ... - .- -.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1304 ![]() ![]() |
According to this post (Thx Stan) they offer an upgrade if you px your old tool. ![]() https://www.fullfatrr.com/forum/post646376.html#646376 2018 SE SDV8 4.4 Byron Blue |
Thanks Kot. However the Gap Diagnostics website currently only shows an upgrade path from G3 to G4. In time I'll contact Gap. |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 259 ![]() ![]() |
How much modification of the CCF can be carried out? All I’m interested in is changing the memory setting so it remembers the previous start/stop setting. 2021 3.0 P400 Vogue
on the GAP website you can use a drop down menu which shows you what ecus you can interrogate ..
Me too, plus I would like to turn off the auto park brake as my environment is very dusty. |
I've ordered a G4 to initially be used on my son's Disco4 to calibrate the turbine valve on a replacement engine then swapped to my L405. The G2s that my son and I both have don't have the turbine calibration function which has to be done so that the Disco can be driven without immediate restricted performance.
