Home > Maintenance & Mods (L405) > Weekend workshop, make your L405 sportier...
Items needed
1. Gap IID or similar high spec diagnostic tool..
2. L405 with ACE..
Plug in your IID etc and load up the CCF (Car Configuration File)
Ensure Dynamic response module says "fitted"
Change dynamic button to "fitted"
Then load the file...
Job done, no hardware needed, use the response knob to activate, raise it and one click anticlockwise brings it in and your dials turn red, a twisty road sign appears on the dash...!! Lower the knob to turn it off..
What exactly does it do I hear you ask........ well..!
That depends on what you read or believe anywhere from absolutely nothing to a host of things which include
1, Gearbox holds gears a bit longer, and/or sharpens changes.
3, Less body roll
4, Sharper steering
5, Better throttle response
To name but a few....
Personally I like it, it feels to me like fatty is just a bit fitter and runs really nice...
I defo think the pause time when you hit the throttle is about 1/2 what it was...
The 18 year old boy racer in me loves the red dials but I don't think I'd want it all the time... Rolling Eyes
Anyway if you fancy a quick and free mod it's free, easy and reversible...
What's not to like... Thumbs Up Pete
Post #713030 28th Feb 2025 7:33pm
fisha
I'll need to try this, thanks.
Edit - Tried it, and for me:
What it does: turning the terrain response into dynamic brings up the red dials, and stiffens up the steering ... at all speeds, even at slow speed car park stuff. I would have thought the low speed stuff would make the steering lighter feeling. ( Like the L322 used to do ) If anything, I think evoque had a more noticeable difference in this regard and worked a little better.
What it doesn't seem to do for me on first test drive:
Change / enable a difference in the gearbox / throttle response. If in D, then changing to dynamic did nothing to the gears ( i.e. it didn't drop a gear ). For that, I had to put the gearbox into S ... at which point it made all the changes you think it ought to.
Cant say I noticed a difference in the lean, and not driven it enough to see if it makes a marked difference to the damping.
Dynamic + S makes for a markedly different drive through in general. Much more keen. V8 or else ...
Post #713077 1st Mar 2025 12:17pm
Interesting appraisal.... seems it does different things for everyone.... Thumbs Up
I think the red dials are worth it on their own.... Laughing Laughing Laughing
 Pete
Post #713115 1st Mar 2025 7:37pm
JamboM3
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Does this work for all model years?
I have long been. Convinced, perhaps placebo like, that sport mode didn’t stiffen things to a sport mode, but made a noticeable difference.. not that it was night and day.
I have a MY17 SDV8 with ace, but kinda cool if I could add a personality to it!
Post #713137 2nd Mar 2025 1:45am
IIRC it doesn't work on the facelift 405 (MY18??) as the IID doesn't work on them, not sure on the 17MY.... I suppose it will if the IID will work on it.... Thumbs Up Pete
Post #713151 2nd Mar 2025 10:27am
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Just been out to do mine. Very quick and easy to do. Definitely a better throttle response and does hold the gears longer in mine. Not really noticed anything else as I didn’t go very far. But definitely worth doing. Thanks for the heads up Thumbs Up 2016 4.4 diesel
Post #713177 2nd Mar 2025 2:28pm
i think the 2018 onwards have this on the terrain control...my 21my one does... ... - .- -.
Post #713178 2nd Mar 2025 2:40pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Will have a look later today
Post #713211 3rd Mar 2025 5:14am
comports
My word Haylands
Makes a big difference - not just a sporty looking dash.
Steering seems more precise and tighter
Throttle response also seems a little better
Rev range is certainly increased.
Not sure but I think there is less body roll as well.
Some of this might be in my head cos of the dash colour though 😂
Great find - looking forward to your next ‘hidden menu find’..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #713311 4th Mar 2025 5:54pm
will308f
right all done but not been out yet to see how it feels .......quick question dose it stay in dynamic mode if you push the knob back down ?
Post #713432 6th Mar 2025 2:36pm
No, it reverts to normal, when the button is down Pete
Post #713437 6th Mar 2025 2:58pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Six years i have had my Fatty and that is a huge difference but i have a feeling the fuel aconomy might suffer, must be good for the 2nd turbo as never seen the rpm over 2000 so much, some strange side effects though radio changed it's self from radio 2 to Kisstory, bass doubled from the speakers and i gained a heavy right foot and wanted to race everyone instead of being a grandad driver. Rolling with laughter
Post #713439 6th Mar 2025 3:57pm
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
[i] think the red dials are worth it on their own...
They must give it another 50bhp at least Very Happy Thumbs Up
Post #713441 6th Mar 2025 4:07pm
will308f
at least 50 bop Rolling with laughter
Post #713442 6th Mar 2025 4:08pm
When you load the CCF it's a bit like disconnecting the battery, a lot of items return to original settings... Pete
Post #713446 6th Mar 2025 6:25pm
