![]() | Home > Technical (L405) > ABS failure woes and will an IID help |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 395 ![]() ![]() ![]() |
I had a problem with the ABS on a 2013 Vogue. Initially I thought it was one of the ABS sensors that was playing up, but it turned out to be the wiring to the plug that connects to the ABS sensor. The wiring was under strain and over time was starting to break.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
What are the error codes that are being reported ? There must be some if it’s in limp mode. V8 or else ... |
maxbasscat Member Since: 11 Jun 2016 Location: South Cambs Posts: 36 ![]() ![]() ![]() |
Screenshot is last play around and the two different vin numbers give the view that the donor ABS ECU requires recoding. I have had various views expressed about how that can be done or not done and my Autel is limited and I know cannot clear so I wondered about an investment in an IID tool and whether it had the capabilities
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 503 ![]() ![]() ![]() |
don't know if this would be the same but on my l322 i had abs errors but turned out to be a abs wheel sensor and fault only cleared after i replaced it with a genuine sensor |
Thanks I am hopeful I have isolated the problem to water within the ABS module, wiring thus far all checks out as good. I really want to follow the logic on IID tool and reprogramming as last post.
