![]() | Home > General (L405) > Hybrid - which engine? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3880 ![]() ![]() ![]() |
I think it may well be inevitable that when I change my V8 diesel I'll be getting an electric RR as my driving pattern has changed considerably recently. I do lots of very short journeys (less than 10 miles) now with the occasional (fortnightly) jaunt down a motorway. On the motorway I tend mostly to drive around 60 - 70 mph to keep out of the way of the HGVs with the occasional need for speed when overtaking. The motorway journeys are a minimum of 20 miles with another 20 getting to the motorway. I initially turned my nose up at diesels because of the potential oil dilution problem I read so much about but then I realised that the short journeys would be completed on electric only so this might not be an issue, I'm not even sure they all have DPFs either. I never tow, never go off-road so my current car is probably a bit of overkill although the shove in the back when you put you foot down to overtake is very nice.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2610 ![]() ![]() |
Cranks aren’t the worry with 2l Ingeniums (and I haven’t really read much about P400e engine issues). |
As our America friends would say thats quite a chunk of change extra and I like the L405 much better that the L460 (I'm sure it will grow on me). Obviously another option for the L405 would just be a 5L petrol. Geoff |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 968 ![]() ![]() ![]() |
I was thinking about hybrids but am being put off by the costs of the repairs to the hybrid unit when it goes wrong? |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 922 ![]() ![]() |
I was loaned a P400E Sport when my FFRR went in for crash repairs (not my fault!! |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Early pheasant had a lot of trouble with the electric heaters failing …..is this still the case or have the manufacturers solved the issues? This problem was not limited to JLR but across a wide range of Hybrids who used the same technology for heating when in battery power. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1304 ![]() ![]() |
So wanted to add Tinmans thread but the video doesn't work !!!!! anyone got another link?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35588 ![]() ![]() |
i read somewhere that around 70k miles you start having problems with the battery...
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 259 ![]() ![]() |
I’m now a month into a 2021 P400 (not e) petrol. It’s giving similar mpg to my previous TDV8 so maybe worth a thought. Straight six as well. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
Hi All, What was reported by High Peak Autos is that we should expect that most Hybrid's will fail after 70k miles, as with any electrical component they tend to have problems?
chicb Member Since: 27 Nov 2019 Location: Dundee Posts: 100 ![]() ![]() ![]() |
I'm thinking that the p400e will suffice for my needs. As my old boss used to say "there's always a good reason not to do something" and as chicb says the internet will give you those reasons. I bet there are hundreds of satisfied customers with p400e's blissfully unaware that the internet says they should have had a new battery |
Geoff,
Are there any 10Y old P400e yet? 2018 SE SDV8 4.4 Byron Blue |
