![]() | Home > Technical (L322) > Park brake fault. |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 191 ![]() ![]() ![]() |
Warning lamp failure makes me think its not the actual operation of the park brake but rather the electric circuit that activates the handbrake indicator on the dash. Is the light coming on and going off as it should? I suspect an issue at the park brake itself related to the wiring such as a corroded connector. |
Armitage Member Since: 07 Jan 2025 Location: Dublin Posts: 3 ![]() ![]() ![]() |
I will try to remove and inspect the loom from the brake module to the left side boot space. The connector did not appear to have any signs of corrosion but it is possible there could have been hidden within the connector.
And yes, the red light goes off when the engine is started/park brake released |
