Home > Technical (L322) > Air quality sensor - location
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi all
I have just found this part lying on top of the auxiliary coolant pump. I gather it is a BMW Air quality sensor.
However I cannot see where it is attached, it has what look like mounting mouldings on the reverse so it must clip onto the body work or a bracket of some sorts.
Anyone know where it goes?
Thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #712714 24th Feb 2025 7:02pm
Drivers side at the top of the rad IIRC
Should be in the workshop manual... Thumbs Up Pete
Post #712727 24th Feb 2025 9:13pm
bigbo
I cannot find it in the manual nor in any parts diagrams.
Does any one have the LR part code?
It must fit to the right of the radiator near the auxiliary coolant pump due to the length of the cable.
MG TF 2003
Post #712735 24th Feb 2025 10:10pm
Sorry I was mistaken, it's the fan relay by the looks of it...
Google 00612010 BMW or 462251 BMW (the numbers on it) and you should find it... Thumbs Up Pete
Post #712767 25th Feb 2025 3:06pm
bigbo
Interesting, we are both correct, I only searched for the top part number which brings up air quality the lower part numbers refer to fan relay.
So it does two functions.
Still doesn't solve the location problem though. I will have to have another good look tomorrow.
MG TF 2003
Post #712774 25th Feb 2025 4:28pm
bigbo
With a closer look under torch light I found its mounting place. So for anyone in the future...
Its not very secure so I will try to sort that.
MG TF 2003
Post #712891 26th Feb 2025 8:30pm
