Home > Technical (L322) > Ignition switched fuse for dash cam, via USB box
DEEBEE(060)
United States 2012 Range Rover HSE 5.0 V8 Orkney Grey
Wiring in a dash cam to fuse box to save having trailing cables. Looking for the best ignition switched fuse to tap in to. Going to be feeding a USB box and then the dashcam, so looking for something of 15 amp so I can use a 10amp fuse in the tap. Ideally something that is no big deal if it happens to blow. 2012 HSE NA.
Post #712652 23rd Feb 2025 10:12pm
fisha
Although for things like the evoque and L405, you can buy short looms which connect directly into the overhead console to provide power from up there near the camera location. Not sure if there is a L322 version ( not looked ) V8 or else ...
Post #712656 23rd Feb 2025 10:34pm
