Home > General (L405) > Help Required.
f4rrs
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
Help Required.
I have a chance to buy a 2016 L405 4.4 TDV8 with 120k from auction. I went to see the car and it had oil in the coolant tank and walked away thinking it had an head gasket issue. After researching the issue it seems the likely cause is a faulty oil cooler. Any help and advice would be greatly appreciated. TIA Paul
Post #712624 23rd Feb 2025 5:37pm
mjdronfield
Known issue on the 4.4. Should be able to sort for less than a grand if you can confirm it’s that. Oil down back of engine out the V and you should see loads from underneath.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #712626 23rd Feb 2025 5:49pm
