Home > My Range Rover > After 2 years of trouble free ownership ...
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
So here I am, just clocked up 2 years with my late 2012 L322. In that time I have covered 17K miles and just hit 70k. I had noticed the burning oil smell in the cabin on occasions and also when I stepped outside of the Rangey. It is the oil cooler. The oil can be seen on and around the cooler when I shine a torch down inside the donut.I have arranged for it to go in to a specialist and plan to get a new cooler and do any other nessary preventative maintenance while he is in there. I will keep you all updated but it seems to be a well documented issue with the TDv8.
Post #712543 22nd Feb 2025 10:14pm
While he does the cooler, get him to check the orings on the turbo feed pipe at the back of the engine.
https://www.fullfatrr.com/forum/topic35977.html
Cheap fix, and easy to do as a preventative while messing with the cooler. There is nothing that can't be fixed with a hammer😜😜
Post #712818 26th Feb 2025 8:09am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Also check the coolant reservoir for oil. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #712830 26th Feb 2025 11:50am
Weegie
When mine was done I had the serpentine belt and the tensioner replaced at the same time. 70K might be a good time to do it. Just a thought. Confused John
GAP iiD BT-Sold
Post #712849 26th Feb 2025 2:09pm
