Blind spot monitoring fault | |
 | Click image to enlarge |
I wonder if someone might be able to help me fault find on my blind spot monitoring system.
I fitted a new towbar a couple of weeks ago and I've since noticed my blind spot system doesn't work now. I've had a look at the wiring and can't see any damage and it all went back together ok so I assumed I hadn't damaged anything.
I have the two orange dots in the wing mirrors and get a 'reverse traffic detection not available' when selecting reverse. If I unplug the wiring I get a blind spot monitoring not available fault, so I was thinking it's a faulty component rather than break in the wiring? The general fault code is on the picture attached.
On the IID gap tool, when I select live valves I just get a system faulty message. Bit stuck where to go from now to pin point it, or just bite the bullet and buy a new loom and sensors?
Any advice greatly appreciated
