Home > Maintenance & Mods (L322) > Sump Oil Plug Tap
this_is_anarchie
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Sump Oil Plug Tap
Hi all,
Does anyone have any experience with the tap style sump plugs (as per the picture)? Are they worth it? Are they likely to open on their own etc?
Thanks
 1993 Range Rover Classic 3.9 Vogue
2007 Range Rover Vogue SE 3.6 TDV8
Post #712392 21st Feb 2025 12:52pm
Strider
Hi
I did buy one but never fitted it as initially I found a external rib in the way on the sump casting. I was about to Dremel grind the rib down locally but had second thoughts about fitting it and didnt...its still in my odds and sods drawer. (It is very well made though).
My reasons :-
1/ The shape juts out quite away (40 mm from seating face).... a risk of getting caught when passing over something that maybe is clipped by the tyre and jumps up and hits the underside tripping the release or snapping the valve off.
2/ The lever is held in a notched recess by a spring......springs can fail. I did buy the extra locking spring clip to fit as well (See picture).
maybe too cautious ??
Post #712418 21st Feb 2025 3:36pm
D3Jon
I'd be a bit worried it opened on its own!
Probably great for a stationary engine installation, or marine application, but really not sure under a moving vehicle? 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #712422 21st Feb 2025 4:08pm
Shaun_
I've used these on dozens of vehicles over thousands of miles. They are indeed very well made. The recess the lever sits in is pretty deep the spring holding it in place quite strong - I don't think it would be possible for it to undo unintentionally.
Similarly you'd have to be incredibly unlucky for the lever to be hit or caught by something and break off.
They make draining the oil much cleaner, especially if you fit a plastic tube which also enables you to avoid chassis members etc. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #712512 22nd Feb 2025 4:01pm
Rambles
Several forum members use a vacuum oil extractor if the engine has a vacuum oil extractor pipe
Not an exaggeration to say an oil and filter change on my MY11 4.4TDV8 takes me 10mins max
No need to get under the car and catch warm / hot oil into a pan / drip tray
Post #712587 23rd Feb 2025 12:16pm
Merchy
Good idea 'IF' there is plenty of clearance to prevent it being struck, especially when off road.
Personally if fitting one I would fit one where the outlet side has a threaded plug with a sealing ring, so that even if opened accidentally there would be no oil loss. Lots available on the web. example below.
https://www.googleadservices.com/pagead/ac...amp;adurl=
Post #712588 23rd Feb 2025 12:25pm
