Home > Maintenance & Mods (L322) > L322 Central Locking
this_is_anarchie
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Hi all,
My L322 (2007) will not lock or unlock with the key fob. I have to put the key in the door but this sets the alarm off. I don't think it is the key battery as neither key will activate the central locking. Is this a quick fix/ common issue?
Thanks 1993 Range Rover Classic 3.9 Vogue
2007 Range Rover Vogue SE 3.6 TDV8
Post #712255 19th Feb 2025 7:40pm
Merchy
First check worth trying is to change a key battery, or both, it could be a coincidence where both key batteries have failed. Worth a try and cheap to do.
Post #712283 20th Feb 2025 9:51am
jordon0
United Kingdom 2010 Range Rover Vogue SE TDV8 Zermatt Silver
Hi i do believe a 2007 has a rechargeable battery so needs to soldered in to key
But its been a long time so may be wrong
Post #712316 20th Feb 2025 2:17pm
