Home > Technical (L322) > Lower control arm bolts
Andy
I’m replacing the lower arms today as they failed the MOT
The bolts were seized solid. It’s taken a couple of hours to get the nuts off. Luckily I’d bought new bolts.
I’m just wondering why LR thought it was a good idea to thread the bolts almost all the way instead of having a shank on them. The bolts I took out had worn where they pass through the holes in the chassis. The short shank section is fine but the threaded bit has worn and rattles around in the hole.
I’m sure a snug fit shank would’ve been better.
 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #712158 18th Feb 2025 5:40pm
Scouse Exile
The bolts that come out from mine do have a shank, of sorts at least. I know from bitter experience of taking several hours getting mine out as they were also stuck pretty solid.
Old ones:
New ones:
Mine is a 2007 3.6, could have been changed at some point. Yours look much longer??
J
Post #712184 18th Feb 2025 9:59pm
dingg1
Are those the bolts that attach the knuckle to the strut??
Post #712199 19th Feb 2025 4:47am
Scouse Exile
Yes, am I talking Censored then Laughing They are control arm bolts aren’t they as the title clearly states Rolling with laughter
Post #712200 19th Feb 2025 5:36am
