![]() | Home > Maintenance & Mods (L405) > no warm air from foot vents |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 145 ![]() ![]() ![]() |
You need to access an OBD port scan tool to check that the blend doors are moving. It is not uncommon for the plastic gears to lose teeth in the blend door actuator. With a scan tool on live climate data you will see a readout for the blend door position on the left and right hand sides.
dave the builder Member Since: 12 Nov 2024 Location: North Wales Posts: 36 ![]() ![]() ![]() |
Thanks appreciate the help. |
