Home > My Range Rover > My new Range Rover… L322 4.4tdv8 Vogue.
Ian7430
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Picked this up last week and am already hooked… such a lovely drive. Takes some getting used to as this is my first 4x4 let alone Range Rover.
Please excuse the pictures, a frosty morning and dirty roads aren’t showing it at its best.
A newbie question if I may? One of many no doubt but I’ll start small 😀
It has a Westfalia tow hook. Missing the actual tow hook and the assembly is rusting…. As I have no use for it I wondered if it is an easy job to just remove it. I assume it was a dealer fit option? Seems to just bolt in place but am I missing something? Will it mess up the electrics for instance if I just unplug them?
Edit: I’ve just found a video on removing it and it doesn’t look straightforward at all!!
Thanks…..
Post #711213 6th Feb 2025 12:24pm
You will be missing some bits if you just remove it. There are a couple of bars which come off when you fit the bar. They would need to go back on.
Electrics could just be unplugged I suspect. Personally, I would just tidy it up with some black paint and leave it alone. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #711223 6th Feb 2025 1:44pm
Ian7430
Thank you, I was just reaching the same conclusion. A tidy up it is.
Post #711228 6th Feb 2025 2:47pm
mjdronfield
I think you can get a bung to go in the square hole. I even think you can get an aftermarket LED reversing light too…..
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #711232 6th Feb 2025 3:27pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #711233 6th Feb 2025 3:31pm
Ian7430
Yes stumbled across the bung, got one on order.
Post #711234 6th Feb 2025 3:43pm
