Home > Range Rover Classic > Range Rover Classic Immobiliser
this_is_anarchie
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
hi everyone,
having some issue with a classic i have just bought. the key does not work in the door to unlock it. i locked it and then unlocked it by pushing the latch down. now whenever i open the drivers door it sounds the alarm (neighbours aren't happy!). any ideas? Range Rover Vogue SE 3.6 TDV8
Post #711123 5th Feb 2025 3:30pm
DavidL
The key doesnt work in the lock; so do you have a different lock set ignition to doors? Does the key start the car?
Does the key work in either door?
There is a fuse for central locking (if you have it) and the alarm, you can always pull that whilst you work out why the key won't work. Otherwise you may need to change all the door locks and ignition barrel to a known set with a key.
Post #711195 6th Feb 2025 9:36am
