Home > Technical (L322) > inconsistent oil level
cornish bob
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi is it possible for diesel to get into the engine at any point, runs ok but had an issue last week runaway
lots of smoke but manage to shut it down ,would not restart, stripped out manifold pipe work etc cleaned and put back together dropped out what little oil remaining refilled run up onk been out an done a few miles all seemed good but now rechecked the level and was showing over filled drained about a litre out now it seems to be reading ok but it was not initially over filled {8litres) any ideas cheers Bob
Post #711026 4th Feb 2025 2:54pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Can only offer a educated guess I am afraid but I wouldn't drive it until you get it properly fixed otherwise you risk permanent and terminal damage to your engine and turbo's.
Leaking fuel injector
Constant DPF regens
Good luck. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #711028 4th Feb 2025 3:11pm
Rambles
Service by the manual say to put in 9.5 litres of oil after draining old oil out
If you do this, your car may show as over filled
But will drive as normal
Some prefer to only refill with 8.5 litres oil and top up as required
Some folk think the turbo drain mod is necessary to avoid runaway
Personally I don’t lose sleep over this
The smoke…what colour was it?
How did you shut down the runaway?
Has you RR had the turbo drain mod?
Post #711058 4th Feb 2025 7:49pm
cornish bob
Thanks for your replies, smoke was grey lots of it ,stopped it by jumping on the brakes and switching it off I was almost on the hard shoulder,not had the turbo drain mod,I'm worried about using more beans at the moment I'm going to run it for a week or so then do an oil test to see if it is getting diesel mixed in with it and keeping an eye on the level
Post #711066 4th Feb 2025 9:05pm
