![]() | Home > Wheels & Tyres > Pirelli Scorpion NCS puncture |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
I appear to have a slow puncture in the near side rear tyre.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
I had the following experience and eventually bought a new tyre. Take it to ATS for 2nd opinion, you might get an official reason why it cant be done. It might be residue glue from foam pad, cant see how a bit of lightweight foam can cause a balance issue either.
I know they can be repaired as I was looking at part worn NCS on eBay and most come with one repair. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35548 ![]() ![]() |
providing its not near the sidewall then yes its can be repaired...its a bit fiddly cos you need to clean the area around the hole carefully so as the glue can stick properly. ... - .- -.
I bought them from Kwik Fit. I’ll give them a call in the morning. Thanks 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
