Home > Maintenance & Mods (L405) > SDV8 Turbo drain pipe mod
Red Throbber
United Kingdom 2013 Range Rover Autobiography SDV8 Barossa
Hi all.
Does the SDV8 have a turbo drain pipe mod? It's a 2013 4.4.
We're taking the sump off to do the oil level sensor, and we're wondering if there is anything we should do while we are deep in the oily stuff. Thanks in advance, Ian
Post #710947 3rd Feb 2025 4:11pm
GraemeS
Australia 2012 Range Rover Autobiography TDV8 Bournville
If the secondary turbo has only 1 drain pipe then the mod hasn't been done. IIRC it was during the MY14 production run that twin pipes were factory-fitted. However if it doesn't have the smoke issue then it probably never will.
Post #710964 3rd Feb 2025 7:44pm
