Home > Technical (L322) > Oil cooler and belt 2011 4.4TDV8
tigmutt
Just had a garage replace the oil cooler which had been leaking. When I collected the car they initially said everything was fine, then when he started it to drive it from the workshop, the serpentine belt was squeaking and rattling like Censored . Is this likely to be something they have got wrong with the repair as there were no issues with the belt when I dropped the car off?
Post #710737 31st Jan 2025 10:13pm
JMC
Removal of the oil cooler has nothing to do with any of the belt(s). It's always possible they may have spilled something on it though. The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #710743 1st Feb 2025 12:19am
tigmutt
Ok thanks. I’ll replace the belt.
Post #710758 1st Feb 2025 2:02pm
PeteT80
Check the tensioner and pulleys for any play, if you need to replace those then it’s worth doing alternator and water pump at the same time. Can get expensive very quick but it’ll save stripping it down again.
Post #710761 1st Feb 2025 2:27pm
